I have a 2000 750SSie ('99 build) I got a throttle tube off an R6 to do them much talked about QAT trick but the SS has only one cable and the whole thing is totaly different. Has anyone fitted this mod to an SSie or am I barking up the wrong tree. I also have a pair of levers to fit but they did not come with the bit that pushes in the end of the master cylinder. I tried to get the old one out of an old lever but it turned to mush when I screwed it. Can I just buy new ones or is there a trick to getting them out?
