1200 DVT Quick Shifter Advice
Discussion in 'Multistrada' started by JohnoDuc, May 7, 2022.
  1. Everything about the DVT I like but would really like to see what it’s like with a quick shifter.
    I have no idea about them or fitting them to the DVT. Has anyone fitted one and can give me some advice on types and fitting etc?
  2. Had a Healtech one on my first DVT, wasn't a good experience. Didn't suit the box and didn't work smoothly even after tweaking. Was only an upshifter too.
  3. I've just fitted a healtech.
    Was a bit dodgy to use on first rides, false neutrals, clunks and engine cut a when I didn't want them:
    Mist of the problem was me getti g used to it and getti g the settings right.
    It's perfec t now... slick gear changes EVEN 1ST TO 2ND!! .... no false neutrals and no clunks... works down the box in higher gears too (tho I'm not a fan of doing that)
    Very happy now
    Settings :
    Sensor sensitivity changed from stock to 60%, min rpm dropped from 3000 to 2500
    Cut off time 85mS, cut off delay 25mS
