Quick Shifter To 2014 Multi.
Discussion in 'Newbies Hangout' started by AndyPandyP, Aug 22, 2015.
  1. Hi all
    I've just joined the forum so forgive if there has been an historic thread on this.
    I am interested in adding a quick shifter to my 2014 Pikes peak but do not want to spend a small fortune, my local dealer was quoting some £800 plus. As a sort of comparison I had one added to my triumph 675 by the dealer that was only £200 ish fitted.
    Anyone got any ideas?
  2. I'm fitting a translogic to my DVT when it arrives, I'm going to fit the gp shifter in the linkage rod rather the a linear one .
    Your triumph would have had a translogic (rebranded triumph) on the trumpet its plug n play and a simple add on, on the duc there's a bit more involved and you have to connect to the 4 coils so some electrical skills are ideal, the kit alone is quite costly where as your triumph only needed the gp sensor .
  3. Thanks Dave, that's useful info and explains the reason for the cost. Thanks Andy.
  4. And welcome Dave :)
