1199 Quick Wheel Question
Discussion in 'Panigale' started by BIG M, Jan 31, 2015.
  1. Can you put the front wheel off an 899 on an 1199 and vice versa?
    Cheers Jason.
  2. Im sure its a yes as the base 1199 has the same looking design as the 899
  3. Cheers, yes I was thinking that but thought I'd better check, I'm assuming they use the same size brake discs?
  4. No idea if the offsets are different but the 899 uses 320mm discs and the 1199 uses 330mm.
  5. Would you not need spacers. Is the 899 std track ?
