Quite Like This Bike
Discussion in 'Supersport (1974-2007)' started by Vader, Mar 5, 2025 at 6:59 PM.
  1. Early finish so as the sun was shining I thought I’d go for a ride on my new SL. Did 40 miles, I like the bike but it’s like sitting on a plank of wood. I either get the seat gel filled or get a fat arse!
  2. I agree it's not the most comfortable. 150 miles is the most I've done on a summer's day.
  3. i'm rusty, but common mod was to swap rear damper unit with the latter 900 i.e. equivalent but forgotten the exact reason:- could be longer travel/longer spring or more sophisticated damping - research will reveal.
  4. 10mm longer, it sharpens the steering a bit. :upyeah:
  5. that's it, like my guess then - longer. The reason for fitting is to try and preserve people's kidneys though, not because of the geometry! :upyeah:
  6. If there is blood in your urine, it's time to fit a softer spring.
  7. Pair of cycling shorts with pad to soften the ride?
