R&G tail tidy
Discussion in '848 / 1098 / 1198' started by jangol, Feb 19, 2014.
  1. Evening all,
    Having a clean up & found a tail tidy, not sure if it's for my old 749 or 1198.. I've got a new 1098 so fingers crossed it will it.. Can anyone confirm for me lol[​IMG][​IMG][​IMG]
  2. Google pictures should help you out, probably take less time than it took me to type this reply.
  3. Thanks for your reply,
  4. It appears to be a 1098 one, that was easy
  5. Aye that's a 1098 tail tidy. Only problem I had with the R&G one the number plate light effectively holds the 2 ends together (well along with the number plate itself). I found it cracked the number plate light. So if you have the inclination it might be an idea to make an alloy backing plate to go behind the tail light to stop the all plastic number plate light from cracking (unless R&G have improved since I had mine)
    John
