Race Evo Up Map upgrade?
Discussion in 'Panigale' started by Kian, Jun 30, 2013.
  1. Hi all
    I had the full Termi system fitted by CMW on Saturday; excellentquality of series and very friendly.
    I understand that there is an upgrade on the Race Evo Up Map; Iwould like to know if anyone had this new upgrade and if so was there a noticeable difference to the Race Evo? Thanks
  2. I am assuming that you used the USB stick that came with the slips to enable the Termi tune?
  3. Yes, the USB Up Map(Race Evo) has been downloaded, but there is an update on this USB which comes with the full system. I would like to know if anyone has the latest update, which must be done by the Ducati dealer, and was there a difference in performance?
  4. The latest map files are version 0206, released in Dec I think. The upmap doesnt actually have the map files on it, it just unlocks the mapping already on the ECU. Your only real option to get the latest is to get to a main dealer to connect and see if there is a new map available, I know you can't tell yourself from the display.
    Another option to you is to consider is to purchase tuneboy which is a USB flash-device that you connect in the diagnostic port and can either upload pre-made tune files or edit your own. I only have the standard pipes but found the bike to ride much better when using their tune file than the factory one.
  5. Thanks for your comments. My Ducati dealer (CMW) will be upgrading the mapping to the latest version as soon as I get my bike to them. I was curious to find out what performance difference am I likelyto notice.
