Hi all im after all the bits to convert my road shift pattern 1199 to race shift if anyone can help me out , im not sure what I need if im honest be it the quick shift switch or the whole linkage all help apriciated thanks chris
Are you using the standard rearsets? If so you will need the reverse quick shifter part no 96676410B However the likes of Lighttech rearsets for example will allow you to use the existing QS.
Hi mr c it has the dp rear sets fitted ? is it just a case of spinning the selector on the gearbox 180 ? what do I need to do with the switch ? cheers chris
sorry bradders you answered my question about the 180 spin , but will I still need to order the reverse switch cheers chris
