I’ve been absent from here for a while, so hello to you all once again! Done a bit of searching but unable to find any info. Does anyone know if said dash can be fitted to a 999 race/track bike? Original race dash has been destroyed in a crash so looking to upgrade! Cheers
Yes if you delete the immobiliser. @chrisw can confirm but as long as the ECU and clocks aren't asking each other if it's ok to wake up you should be good. The dash2pro will run your fans as well. I've got a dash2 to fit to the 916 when it get built, they're great bits of kit. @bettes had a pro fitted to his 998. Edit: to run canbus on original DASH2 you need the canbus interface seperate module.
You need the dash2 pro as the 999 sends info between the ECU and dash by canbus Here is an old post where I explained how it may be possible to fit a non-Canbus dash on a 749/999 https://www.ducatiforum.co.uk/threads/racing-dash.78265/
Thanks Chris, it’d be the dash2 pro that I’d be interested in getting so should be ok. As always, your info is great
