On removing my front fender to remove my front wheel as i am going to have new tyres fitted i noticed the bottom Radiator vibration damper bracket had come out of pad and was hanging to one side, just wondering if this should happen or maybe it wasn't correctly fitted when it was serviced last month... The said item is number 6 and 7. The top two and bottom rear have bolts that secure them in place but the front bracket on the bottom of the radiator does not... https://www.bike-parts-ducati.com/d...strada-1260-ABS/WATER-RADIATOR/384/2309/0/384
I believe you will find that the lower radiator bracket (6) is a push fit but the rubber bush (7) has to be fitted into the bracket on the radiator. One of them certainly is on my 748. Andy
