I've found a source for stainless steel versions of the pad pins for the front brake calipers but it looks like nobody makes replacements for the rear caliper pad pin. I have a couple of potential sources for making the rear pad pins but need to send an OE item for use as a pattern - before I strip mine out just wondered if for any reason someone has already replaced one and has the old one kicking around surplus to requirements? Part (14) Thanks
Pro Bolt might make some up. Then again they'd charge a bit for them. Got their s/steel front brake caliper mounting bolts and look good fitted to my mutley.
Hmmm difficult choice, I know what I'd be doing if I had the cash to burn! Shaw Stainless - I've dealt with Chris in the past DUCATI STAINLESS STEEL ID: F SERIES PIN STAINLESS STEEL FRONT BRAKE CALIPER PAD PIN .....I'll see if I can negotiate a discount for forum members ;-)
