Rear paddock stand pin size 1199s
Discussion in 'Panigale' started by JohnR, Mar 31, 2013.
  1. Just bought a 1199s, and have a paddock stand from my 848. Although spindle size is different, any one have a drawing so I can machine one up as the stand its self should be ok.
  2. cant you just copy what you have and change the bit that goes into the spindle to the correct diameter ....43mm?
    Aint it going to be the same as the 1098 1198..
  3. My first thoughts Andy, just wondered if anyone had a drawing as there maybe 2 diameters if its like the 848 type.
  4. As long as it fits yours?
  5. 1199 is a 40mm paddock stand pin, same as 1198 and 2008 on 1098 (2007 1098 was 38mm, 848 is 25mm).
    I got my pin from Ducati mondo to use in my existing paddock stand, cost around £20 and bolted straight in.
