I will be changing the bottom ball joint on the threaded adjuster due to a little play , that is no problem but is there a distance between the bearing centres ? Also is changing the oil sight glass as straight forward as prizing the old 1 out and pushing the new one in ? Thanks for any advice in advance .
Ride height adjuster eye to eye centres regular setting 285mm which is also max recomended height according to handbook. Be careful with sight glass, don't think they come out or in easily. If its misted up try putting a 50w halogen spotlight an inch or so away for a few hours.
