Rear Seat Lock
Discussion in '848 / 1098 / 1198' started by gman2050uk, Feb 20, 2015.
  1. Hi guys after taking my daughter on the back the other day I noticed the barrel of the seat lock was no longer their, hoping it was still attached to the cable but after removing the rear faring no luck it was gone :( now what are my options as its the barrel means new different key too :(
  2. Strange. I think the lock is held on by a large nut inside the rear fairing which spins on over the lock itself.
    No idea on replacement I'm afraid. I expect you could get a replacement but it will have a different key. Short of replacing the whole lock set and ignition it may be that you'll need 2 keys.
  3. Mine went awol on my 998 - never felt the need to replace it but they were about £30 odd quid from Ducati. Does it matter if the key is different if you need one fitting?
    #3 Exige, Feb 20, 2015
  4. Nuh I would prefer that then just a hole lol would give them a bell tomorrow.
  5. I would have thought that as there is a mechanical key number on the code card you will be able to get one that fits your existing locks, will need programming though I expect just in case you wish to use it to start the bike.
  6. I checked with a Ducati dealer and was told not.
  7. im building a 848 back to street mate i have a extra barrel pretty easy to make it fit your key.
    once you put your key in you will have 1-4 brass pins stick up. put in you key what ever ones that are sticking up just file them down and walla your key works
  8. pm me and ill walk you through it
