916 Rear Seat Mesh
Discussion in '748 / 916 / 996 / 998' started by Messer, May 3, 2019.
  1. Bought some new mesh for the vents on the tail of my 916, to stick it in am I right I’m using sikaflex or mastic type stuff?
  2. I use clear mastic but it takes a while so I tack down with hot glue gun in the corners.
  3. I nailed mine on.
    • Funny Funny x 5
  4. I used double sided sticky number plate foam stuff - came in a roll like sellotape. Works for me!
  5. From the factory they used a white double sided padded taped - very similar to the Halfords number plate fitting tape which is black and around 10mm wide. I must admit, I used hot glue on mine as 'mastic' takes too long to cure and it is somewhat fiddly. Good luck!
