Rear Tyre Size
Discussion in 'Tyres' started by ELW27, Apr 18, 2018.
  1. Good afternoon everybody,
    Looking for a smidgen of advice
    I currently use Metzeler Racetec RR K3's on track, but thinking of changing and using a K1 front and K2 rear. I currently use a 180/55 rear, but have seen you can get 200/55 rear.
    The advice I would like is: Is there any advantage to using a 200/55 rear instead of a 180/55 or is it best to stick with the 180?
    Any help would be most appreciated
  2. The 200/55 needs a 6" rim. If your stock tyre is a 180/55, then you've probably got a 5.5"....... just looked at your profile. The 848 is a 180/55 on a 5.5" rim. You wouldn't get a 200/55 in the swingarm. We've just tried getting a 180/60 in to a customers bike and without lengthening the chain, that wouldn't fit, so no chance with the 200
  3. Thank you for your response, that's cleared it up for me! 180/55's it is!
