HI All Went to replace the rear tyre and worked out that the nut for the rear wheel is completely different to that of the 848. So question is where can i get one from in the UK? i had a look on ebay and can see one thats been made for £65 any other options out there? thanks Trevor
If its the 55mm HEX, draper do one...here. You may also need to buy a 1/2" to 1" socket adapter and prob as long a torque bar as you can get. Alternatively people use these Clarke wrenches
55mm and a mains powered clarke impact wrench gets the nut off great, just tape the nut up to stop it getting marked if using a impact wrench . Can be done by yourself with no help with a impact wrench.
