Recall out of warranty?
Discussion in 'Technical Help' started by yets, Aug 21, 2013.
  1. 749 has sprung an oil leak and it appears that it is coming from the oil cooler. Did a bit of research and 2003 749's, which mine is, were recalled to have it fixed. Am I still entitled to get the work done as a recall?
  2. If the work hasn't been done yet then I think you should be entitled to it. The intention of a recall is a manufacturers legal obligation to fix a fault. If you speak to the dealer they should be able to tell you if the work has been done :smile:
  3. I think there would be time limits on that. 10 years is quite a bit of time before getting a recall done!
  4. Thanks Matt, I'll give local dealers a call. See if I can get some info about the bike
  5. It's worth checking with your local dealer. I had a recall job done on my 94 916 when it was ten years old, at JHP Ducati Coventry.
