1200 Removed Beak - Wiring Question
Discussion in 'Multistrada' started by Fitzjnr, Mar 30, 2014.
  1. Yesterday I took the beak off my 2011 Multi to fit an Evotech Rad Guard. Behind the right one (half way down the panel) there was one push fit wire. I am 99.9% certain I reconnected it but now it is back together I can't see it. I don't want to pull it all down to check is someone can tell me what this wire is and if I would notice anything strange had I not connected it. I am thinking something to do with fan?
    I have had a look at wiring diagrams and can't work it out?
    Thanks
    Stupid!
  2. I think It's the air sensor, if you have a error message saying "engine"on the dash, it means you haven't connected it properly. If no error message on the dash all should be good.
  3. Yep, air temperature sensor :)
  4. Cheers, all appears ok then =)
