748 Replacement Clutch Master Cylinders
Discussion in '748 / 916 / 996 / 998' started by duke63, Dec 28, 2014.
  1. Do later Ducati 848 or even 899/1199 clutch master cylinders fit 748 or will i cause myself problems with clutch disengagement/lever take-up points due to different ratios?
    I also have an Oberon clutch slave to fit so need to take that into account to.
    Bike is a 1999 748 with silver levers.
  2. Yep, they fit and are a lot better than standard 748 ones... highly recommended...
  3. 848/1098 ones?
  4. yep, I put 848 ones on my 748... much better (especially brakes)
    I also had oberon type slave on the clutch...
  5. I already have a Brembo RCS brake master which is a massive improvement and wanted to do something similar to the clutch m/c. I have put some adjustable Ducabike bars on over the holiday and the clutch m/c now looks out of place.
