Cheers - bloody annoying how the range resets though when you switch off. Fuel light came on in the way in to work and did a couple of miles. When I came home it had reset to zero again then on the ride home I went up and down a steep hill which caused the fuel light to go off then on again then it reset to zero again!!! In future I will just reset one of the trips to zero for a true record of distance covered.
My 848 did that too. I don't think it's because you switched it off but more because the remaining fuel got into a position to deactivate it. Does go on and off for a little while sometimes. Generally though as soon as I see the light I'm hunting for a garage!
