1260 Seat Cover Repair
Discussion in 'Multistrada' started by benjit, Oct 8, 2022.
  1. Hi, after some advice please. My seat got knocked on the garage floor and the cover now has a small (2cm ish) split in the cover on the rear right corner. It’s sort of under the pillion seat, but noticeable and annoying. I guess I could send it off to get recovered (prob will in the end).
    Is there a good way to make a temporary repair that looks good enough and will stop water getting in?
    thank you.
  2. Black duct tape is your friend.
  3. If you get stuck, I’ve got a spare seat you can borrow until it’s sorted.
  4. Thanks Sam. I’ve still got my standard one so can send it off to get fixed if needs be!!
  5. Where are you located? My son has a trimming shop near Sammy Millers museum in the New Forest. Hide & Seam
  6. I recently bought a seat that the seller “forgot” had a rip in it so I superglued the two edges together applied with a cocktail stick and then a bit of black polish over it. I honestly struggle to find where it is now.
  7. Thanks - will take a look. I am in Wiltshire.
