Shaved legs!
Discussion in 'Lounge' started by pingping010101, May 11, 2013.
  1. In preparation for injury-preventing taping whilst training this month, I've shaved my lower legs.
    Why do you women do it!?!?
    My legs look like I've been given the cat-O-ninetails by a midget
    They sting like mad and they're cold!!
    At least it's better than having to pull zinc oxide tape off of a hairy leg. Ouch!!
  2. You should try shaving your balls !!! :biggrin:
  3. No womans leg ever looked like your shaved or not :tongue:
  4. I must be lucky, I shaved a couple of times during triathlon training, no irritation at all. The only major downside is the skin on my legs is mega shiny for some reason! It does make like a lot easier when applying sun block or deep heat, too. Apparently shaving arms is common practice for outdoor workers in hot countries for that very reason.
    When I have the next op on my leg my left thigh is getting shaved - holy crap did it hurt taking the dressings off the wounds with them pulling all the hair out.
    :eek:
  5. Tip that a semi-professional pushbike racer gave to my mum years ago and she swears by it: shave your legs underwater in the bath.
  6. Wouldn't you need a snorkel? :eek:
  7. Try waxing next time - shavings so last year
  8. Shaved legs ? try a legless shave .
  9. I cant do waxing it hurts
    I just let my legs warm up in the shower that will open the pores
    Use a good gel all over and shave upwards and try not to use the razor with the gel gone as you will get razor burn.
    Use the razor you use on your face if your a man as it blunts them but sharp enough for leg skin
    Once out of shower pat dry and puta good moisturiser on that should stop any soreness
    Been doing mine for years like this
    Use a cocoa butter if you can
  10. Its amazing the handy tips you can get on a motorcycle forum:upyeah:
  11. And then get yourself off to Victorias Secret and purchase a set of stockings and suspenders!
  12. Doesnt the pool attendant get pissed off?
  13. I did it the man way.
    Shaving foam + Leg + Razor = Bloody mess. No hair though. Not a lot of skin either.
  14. no offence, blokes dont shave their legs
  15. Does that apply to all body parts that have a tendency to grow hair? :smile:
  16. No, you will have to pluck some areas :biggrin:
  17. With your teeth? :wink:
    Oh you mean eyebrows :tongue:
  18. If you can reach 'there' with your teeth you really need to put it on You Porn :upyeah:
  19. I wasn't thinking if my hair. I was thinking of Ducbird's :upyeah:
  20. Your not touching my hair with any tweezers :-O
