I had it fitted to my old m750 after tail chop, looks the bomb as pictures below show. It is from another Ducati model, no idea which one, modified for double side swing-arm fitment. Item is made out of Carbon-Fibre. To fit a flush style swing-arm you will need to drill and thread 1 hole, it uses the stock centre one as 2nd point mount. You fit it only to protect the shock. Fitment on the other style swing-arm (not flush) similar, 1 hole needs to be drilled but it will also need to be tapped and raised to level it with existing hole. Price 50GBP
