899 Side Fairing
Discussion in 'Panigale' started by panigale66, Nov 5, 2016.
  1. Time to change the main headlight bulbs so need to remove virtually everything to do so, but just wondering if I can remove the side fairing and leave the bottom in situ?
    Sent from my iPad using Tapatalk
  2. I'm pretty sure you can (well at least on the 1199). They are a but fiddly as they have some flimsy tabs that slide in and out. You have to pull out the tabs by your knees then "hinge" up the panel and slide backwards.
  3. Yes you can. Just keep an eye out for one or two slightly hidden poppers and don't lose the rubber pieces where it clips in to the ECU tray.
  4. Came off no problem cheers boys
