1260 Side Stand Play
Discussion in 'Multistrada' started by freshage, Oct 25, 2022.
  1. My third mtistrada... never noticed it, but is the side stand meant to have a little play at the mounting bolt? As in, when it's extended, you can 'wobble it' but when kicked in, it's pretty much solid.
    I'm 3 days into a 2 week trip and it's earing into me, even though I'm sure it's fine.
  2. Yeah, I think that’s normal.
  3. Yup. Its a service check item. I've had to close the gap a few times over the years. Avoid using it with luggage.
  4. As @gmoss found, on the odd occasion, I’ll take the side stand off and “close “ the fork up a little by clamping it in a vice. Ideal opportunity to check the hole roundness in the frame lug as well. Andy
  5. Cool, thanks guys. I rarely use it for more than a few mins. I'm always straight to the centre stand
  6. You could always have the hole in the bracket machined out and press in a hardened steel boss, then have a pivot bolt machined with matching tolerance. It would probably outlast the bike.
  7. I'm sure there was a recall / upgrade on the side stand or maybe it was the bolt :thinkingface:, might be worth checking with your dealer, anyway mine has the same play, 50k miles on and it's outlasted the engine :(, used with full luggage on numerous bike tours without any issues.
