Hmmm... complete stripdown? Looks like the recent flooding will bring some good to someone... 2009 DUCATI 1098 1099cc Petrol Manual Motorcycle at RECLAMET LTD Kent, due to close Fri 11th Apr 12:33:30
Full strip down and thorough examination of all the electrics. If you can do all of this yourself (combined with maybe a new wiring loom) you might be on to a bargain. I'd be most worried about the electrics though.
My mate was looking at this one, he is a bike mechanic and thinks it should be easily sorted. I think he's going for it
I would have thought that if its been submerged then there is a possibility the ECU and dash could be toast if the battery was in the bike at the time. Might not be, if its not then everything would need flushed with clean water and left to dry. Depending on the level of immersion I'd also have thought the engine would need completely stripped, flushed and cleaned as well. River water is usually full of sewage and silt, it wouldn't take much to wreck an engine. A bargain for sure but only if you knew what you were doing and had a lot of free time. Just my thoughts John
Looks like a bargain (and In bet you could knock another £250 off too) if you knew what you were doing.
They could also be the street legal Ti slip-ons. Don't the originals have some kind of brushed outer skin? These look smooth.
But this is an auction? It will end up going for silly money, just get a proper one & leave the knackered ones for spares only to some twit that has loads of money..
I'd certainly like to know what happens to the bike through. Mainly out of curiosity, but I can certainly see another £2000 being spent on the engine strip/rebuild and loom work, which would make it a ball ache for a £7k cat C bike
