For Sale Slipper Clutch
Discussion in 'Parts, Accessories & Clothing For Sale' started by Nasher, Sep 5, 2023.
  1. I brought this Slipper Clutch from EBAY a while ago mainly to get my head around how they work and decide if I wanted to try one.
    I’ve had a play with it, brought a Spider spring plus a spare and decided that for what I use my bikes for it’s just not worth fitting.
    The pressure plate is branded Ducati Performance but I believe it’s made by EVR.
    It’s missing the stepped centre nut which allows the Spider to rotate around it in use.
    It will fit most Dry Clutch Ducatis, but I believe there are two different nuts depending on what you fit it too.
    It uses standard plain and friction plates, and will fit with a standard basket, although most appear to prefer an Aluminium one.
    It’s obviously been used, but the marking from the plates on the centre is not as bad as it appears in the images.
    The Balls are all present and the ball ramps on both parts are in excellent condition.
    £190 Collected from Clanfield, Hants, or £200 posted within the normal UK postage areas.
    OLYMPUS DIGITAL CAMERA
    by Nasher on Ducati Forum
  2. £175.00 + P&P anyone?
  3. Last price reduction before EBAY.
    £160 + P&P.
  4. Really surprised this hasn't sold. Similarly surprised you're not keeping it. One of the best mods you can add to a Ducati. It makes engine braking a option at all times.
    Worth £160 of anyone's money imo
  5. @Nasher fyi think its also missing a spacer that sits behind the hub ( but not 100% in that )
    but still a good bit of kit at a great price even with the missing bits ( which are all available )
