For Sale Sold - Termi Cans 1199/899
Discussion in 'Parts, Accessories & Clothing For Sale' started by Sam1199S, Aug 23, 2016.
  1. For sale are my Termignoni end cans with removable baffles (currently removed) and associated brackets that would usually come with the exhaust, plus Up-Map key
    As you can see they're in decent condition overall. The pics show the minor stone chipping to the underside and lower edges of the front aluminium covers as to be expected from use. The line-type mark on the said covers is where the fairing touches. There is also a missing pop rivet on one logo for some reason! Easy to replace and I'll see if I can sort it - the old man has a rivet gun.
    As mentioned they ideally (not strictly necessary however, and noise-wise there's no change) need a re-pack as the inside face of both sides have begun to blue up from excess heat. Over time this could manifest on the visible side I imagine? This hasn't manifested itself on the outside so far and no doubt was born from track use, so if used on the road I doubt there'd ever be an issue. I hadn't noticed this until I removed them to fit the Akra system either as its totally hidden.
    Other parts to be supplied is the Y pipe that joins the two cans and links it to the headers, the retaining springs for this and also the front bracket that supports the front end and attaches it to the bike. I also have the Up-Map key.
    Looking for £600 collected (from Chobham, near Woking, Surrey) or £625 posted recorded and insured.
    PM if you're interested [emoji106]
    Sam
    #1 Sam1199S, Aug 23, 2016
  2. Sam,
    PM'd you
    Best Regards
    Paul
  3. Now sold pending final completion [emoji106]
  4. 99% sure - just packed them and all the bits, and due to post tomorrow after payment. Will let you know if the sale doesn't go ahead
  5. These are sold now. Just in case anyone else is looking I have some Termis coming up for sale. They are not as good condition as these due to gravel rash on one side and a broken baffle bolt on one side that does not stop the use of the baffle but otherwise good. I'm hoping to get them off the bike in the next week or so.
  6. Thread closed
