Up for sale is a Termignoni 57mm full system for deep sump and black swingarm models (749R 2004-2006, 999 2005-2006, 999S 2005-2006, 999R 2004-2006), but I've seen this mounted with the grey swingarm as well. This is the early, round pipe model with a rare titanium silencer. Later banana model has a heavier steel silencer. (similar system, not the one for sale) The system is in great condition, no dents. Scratch on silencer cover on the right side, visible in the pic. Will be mostly fixed with a new decal. All pipe joints are in order and attach nicely, no binding. Included is the pipework, silencer, silencer carbon cover, carbon heat shield for header pipes, mounting springs and an aluminium mounting bracket for the pipes and rear brake master cylinder (springs and bracket not pictured). If needed I can also supply an OEM tail light holder with heat shield and tail light wiring. ECU also available but I'm not sure which map it has loaded in it. More pics of a similar system mounted on a 999R can be seen here Price 1299€ (euro) without ECU, 1359€ with ECU and 1399€ with ECU, tail light mount / heat shield and wiring. Located in Finland, worldwide shipping available. These are not available too often so grab yours while you can jusutus1 at gmail dot com
