Solo Corse Wave Discs
Discussion in 'Solo Corse Racing' started by nogaromill999, Apr 4, 2012.
  1. We have our discs made by some of the companies that make for Nissin and Brembo....namely Sunstar Engineering. Here are some pics, and I have posted a list of all discs we have and it can be used as a cross reference too.
    Normal price is £293.75 per pair, we are happy to offer them to forum members at £250...with free delivery
    Disc SC01-ITYA32
    BRAKING PART CODES STX01/STX62D*/STX73D
    EBC PART CODES MD621, MD633, MD2003, MD636
    SC-01 means Solo Corse disc 01. The ITYA32 means it fits a range of Italian bikes and Yamahas, and has a diameter of 320mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 320mm
    Thickness 5mm
    Central diameter 64mm
    Number of bolt holes 6
    Hole diameter 8.5mm
    Bolt pcd 80mm
    Offset 10mm
    THESE ARE THE BIKES THE DISC FITS:
    DUCATI
    Junior 350 SS 91-
    400 SS 93 –
    M600 Dark All
    M620 /750/900 All
    MS4 01 -
    600SS 93 –
    748 Biposto 95 –
    748 SP 95-97
    748 R * 00 –
    748 SPS 98 –
    Sport 750 01 –
    750 SS 91 –
    851 Strada/SP 90/91
    888 Strada/SP 90-94
    900SL 92-96
    Sport 900 02-
    900SS 91 –
    ST2/4/4S 97 –
    916 Strada/SP/SPS 94 –
    996Bip/S 98 –
    996R/SPS *
    998 Bip/S 02 –
    998R * 02-03
    * 5mm spacer required between disc and wheel
    APRILIA
    RSV Mille 98-00
    RSV-R/SP 00
    RSV/R 01-03
    RSV-R/Factory 04 –
    SL Falco All
    AF-1 Futura 125 90-92
    RS125 Extrema 92 –
    Tuono R )
    Tuono Racing ) all V twins
    Tuono Factory)
    Disc SC01-ITYA32 PAGE 2
    BENELLI
    All triples 900/1130
    BIMOTA
    YB-7 400 89
    V- Due 500 97-00
    YB-9 600 95-
    Supermono 650 96-
    Tesi ID 851 90-91
    Mantra DB-3 96-00
    DB-2 SR 94-00
    DB-4 98-99
    DB-5 05-
    Dieci Biposto 92-
    SB8-R 97-00
    SB-6 96-00
    SB-6R 98-00
    CAGIVA
    Mito/Mito EV 90 –
    Planet 97 –
    Supercity 91 –
    River 95 –
    KTM
    Duke 640 03-06
    MOTO GUZZI
    Centauro 96 –
    Daytona IE 95 –
    CaliforniaEV/Special/ 97 –
    Jackal
    V10 Centauro Sport)
    V11 Le Mans ) All
    V11 Sport )
    Breva 750/1100 All
    Griso 1100
    MOTO MORINI
    Corsaro 1200
    LAVERDA
    All 650/750 models 96 onward
    VOXAN
    Café Racer )
    Roadster ) All models 00 on
    Scrambler )
    YAMAHA
    TZR 125 91-
    TDR 250 89-92
    TZR 250 89-92
    SRX 400 91-
    SZR 660 95-
    FZR 1000 Gen/Exup 87-93
    XJR1200 95-97
    XJR1300 98
    OW-01 89-92
    YZF750 R/SP 93-96
    Disc SC02-SU32
    BRAKING PART CODE : STX20D
    EBC PART CODE : MD3058
    SC-02 means Solo Corse disc 02. The SU32 means it fits a Suzuki and has a diameter of 320mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 320mm
    Thickness 5mm
    Central diameter 69mm
    Number of bolt holes 5
    Hole diameter 10.5mm
    Bolt pcd 91mm
    Offset NIL: THE DISC IS FLAT
    SUZUKI
    GSX-R 600 97-03
    750 all models 96-03
    1000 01-02
    TL 1000 S All
    TL 1000 R All
    Hayabusa All
    GSX 1400 02 –
    Disc SC-03 DU32
    BRAKING PART CODE : STX66D
    EBC PART CODE : MD622
    SC-03 means Solo Corse disc 03. The DU32 means it fits a Ducati and has a diameter of 320mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 320mm
    Thickness 5mm
    Central diameter 72mm
    Hole diameter 8.5mm
    Bolt pcd 90mm
    Offset 15mm
    DUCATI
    749 02-06
    749S 03-06
    749R (Radial Caliper) 03-06
    999 Biposto 02-06
    999S 02-06
    999R (Radial Caliper) 02-06
    Disc SC-04HO31
    BRAKING PART CODE STX47D
    EBC PART CODE MD 1152, MD1153…However, EBC ALSO claim this will fit the 06 CBR1000RR, which it WILL NOT. The 06 CBR1000RR changed disc diameters to 320mm.
    SC-03 means Solo Corse disc 04. The HO31 means it fits a Honda and has a diameter of 310mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 310mm
    Thickness 5mm
    Central diameter 94mm
    Hole diameter 6.5mm
    Bolt pcd 110mm
    Offset 12.5mm
    HONDA
    CBR 600 RR 05 -
    CBR 600RR 03-04
    CBR 1000RR 04-05
    Disc SC-10HO32
    BRAKING PART CODE : STX41D
    EBC PART CODE: EBC do not list this disc
    SC-10 means Solo Corse disc 10. The HO32 means it fits a Honda and has a diameter of 320mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 320mm
    Thickness 5mm
    Hole diameter 6.5mm
    Bolt pcd 110mm
    Offset 12.5mm
    HONDA
    CBR 1000 RR 06
    VTR 1000 SP-1 00-01
    VTR 1000 SP-2 02-04
    Disc SC-11SU31
    BRAKING PART CODE : STX76D
    EBC PART CODE : MD3091
    SC-11 means Solo Corse disc 11. The SU31 means it fits a Suzuki and has a diameter of 310mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 310mm
    Thickness 5mm
    Central diameter 100mm
    Bolt pcd 120mm
    SUZUKI
    GSR 600 06
    GSX-R 600 Radial 06
    750 Radial 06
    1000 Radial 05 –
    Disc SC-12SU30
    BRAKING PART CODE : STX67D
    EBC PART CODE : MD3089
    SC-12 means Solo Corse disc 12. The SU30 means it fits a Suzuki and has a diameter of 300mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 300mm
    Thickness 5mm
    Bolt pcd 91mm
    SUZUKI
    GSX-R 600 Radial 04-05
    750 Radial 04-05
    1000 Radial 03-04
    Disc SC-14YA31
    BRAKING PART CODE : STX78D
    EBC PART CODE : MD2095
    SC-12 means Solo Corse disc 12. The YA31 means it fits a Yamaha and has a diameter of 310mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 310mm
    Thickness 5mm
    Central diameter 132mm
    Hole diameter 8.5mm
    Bolt pcd 150mm
    YAMAHA
    YZF 600 R6 05-06
    Disc SC-15YA30
    BRAKING PART CODE : STX46D
    EBC PART CODE : MD2082
    SC-15 means Solo Corse disc 15. The YA30 means it fits a Yamaha and has a diameter of 300mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 300mm
    Thickness 5mm
    Hole diameter 8.5mm
    Bolt pcd 150mm
    YAMAHA
    FZ6 Fazer 600 04 –
    YZF R6 600 03-04
    MT-03 660 06
    Disc SC-17YA32
    BRAKING PART CODE : STX71D
    EBC PART CODE : MD2094
    SC-17 means Solo Corse disc 17. The YA32 means it fits a Yamaha and has a diameter of 320mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 320mm
    Thickness 5mm
    Hole diameter 8.5mm
    Bolt pcd 150mm
    YAMAHA
    FZ-1 Fazer 1000 06 –
    YZF R1 1000 04-06
    Disc SC-18MV31
    BRAKING PART CODE : STX45D
    EBC PART CODE : MD675
    SC-18 means Solo Corse disc 18. The MV31 means it fits an MV Agusta and has a diameter of 310mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 310mm
    Thickness 5mm
    Central diameter 80mm
    Hole diameter 8.5mm
    Bolt pcd 101.5mm
    Offset 10mm
    MV AGUSTA
    Brutale 750 All Models 01 –
    Brutale 900 All Models 04 -
    F4 750 All Models 98 –
    F4S 1000 All Models 04 –
    Disc SC-20KA30
    BRAKING PART CODE STX08D
    EBC PART CODE MD 4136
    SC-20 means Solo Corse disc 20. The KA30 means it fits a Kawasaki and has a diameter of 300mm. The Braking catalogue shows the following critical dimensions for the disc:
    Diameter 300mm
    Thickness 5mm
    Central diameter 61mm
    Bolt pcd 81mm
    Offset 13.5mm
    THESE ARE THE BIKES THE DISC FITS: ( EBC CLAIMS IT FITS OTHERS TOO BUT I CANNOT VOUCH FOR THIS ).
    KAWASAKI
    ZZR 250 92 –
    ZXR 400 89-90
    Zephyr 550 93 –
    ZL Eliminator 600 95 –
    ZX6-R 600 95-97
    ZX6-R 600 00-02
    ZX6-R 636 02 –
    ZZR 600 90 –
    Z750/S 750 04-05
    Zephyr 750 91 –
    ZR7-S 750 99 –
    GPZ 900 90-03
    GPZ 1100 95 –
    GTR 1000 94 –
    Z 1000 03 –
    ZX12-R Rad 1200 06 –
  2. I'd be very interested to know what actual definition is being used for 'offset'.
    Most technical information that I have been able to dig up on this indicates the accepted measurement is the distance between the (inner) mount surface and the outer surface of the swept area. I actually think this is a bad idea as disc material thickness affects the offset, but anyway...
    According to the above data, a 0 offset disc is flat, but according to the accepted standard I mention above, a 0 offset disc would not be flat. A flat disc would have an apparent offset equal to the thickness of the disc which makes no sense to me.
    The only sensible way to measure offset would be from the middle of the carrier where it mounts on the wheel, to the middle of the swept part of the rotor. That would mean material thickness is irrelevant anywhere on the disc and that a 0 offset disc would be basically flat, even allowing for variations in thickness on different parts of the disc.
    However, it does not seem as if the manufacturers do it that way and indeed there seems to be no standard way of defining offset. Certainly there is a discrepancy here.
