I have a pair of NGK DCR9EIX (Iridium) on my 916 SP3. I couldn’t tell you the gap, quite frankly, but they have been on the bike straight out of the box for 2 years and the engine feels VERY healthy. (FYI, OEM plugs are Champion A55V on this bike).
+1 on the iridiums, I've been using them for years, bike runs perfectly, starts first touch of the button and I can't remember when I last changed them. Gap is whatever they came out of the box with. NGK in your bike, Champion in your lawnmower...
i removed these from my 916 NGK DCR9EIX but wanted to check gap but not having a new one to hand i dont know what it should be any ideas on torque setting?
Never used a torque setting for plugs, just nip 'em up enough so they don't come loose. Tighten 'till the thread strips then go back a quarter turn.
I tighten them by hand, then add 1/4 turn to press the crush washer on the plug. With a smear of copper grease on the threads.
@RC1 As there is no suffixed number to DCR9EIX and looking at that NGK gap chart, I would say that your gap needs to be 0.7-0.8mm. However, iridium electrodes being extremely fragile, I would be super careful when gapping them. I’d use the same spacer tools as for measuring the valve laps.
thats great thanks. i only have conventional feeler guage though im sure my gap is larger than 0.7-0.8
@RC1 Here’s a video I found interesting about gapping iridium plugs. I have never done it myself, as I never really felt the use to do it.
I use surface discharge Champion A55V in my 955cc Desmoquatro. I went over to them from NGK's to save me the problem of choosing plug gaps. They worked a treat I've never had any failures with them and the bike makes good power. They're no longer available but fortunately I've got a good stock of spares of them. Steve R
10Nm NGK state not to use degrees rotation when refitting used plugs. You have to use torque. With new plugs it’s your choice, degrees or Nm.
Interesting, thanks ! This must have to do with the crush washer that needs to be crushed only when new, I guess.
well the feeler guage measured my gap at 0.762mm so back in they went after some more fuel my VARESE bike fired up easy after a long rest now to find a buyer to fund the next purchase!
