St3 Clutch
Discussion in 'Sport Touring' started by SteelCityBaggie, Jul 6, 2015.
  1. Posted this in Tech Help but got no response, so will try here
    I need new plates and basket on my 2004 dry clutched ST3. Now, the question is do I just buy cheaper after market 12 tab parts or do I spend a little extra on a 48 tab option, such as the ones at Speedycom Performance Ltd...
    Also, what is the difference between organic and sintered plates? I use my bike for touring and commuting, so I don't think a slipper clutch is necessary :)
    And finally, does anyone recommend a good clutch tool for occasional use? Would the one below fit the bill?
    DUCATI DRY CLUTCH TOOL WORKS WITH AND T48 BASKET STM | eBay
    Thanks in advance
  2. How bad are your plates and basket??
    You could try doing a quiet clutch mod first without spending anything.
    With the mod done, the tabs no longer chatter about in the basket slots, so as long as you have enough material on the friction plates, the clutch may well be fine as it is.
    All you need to do is put a friction plate in first and make sure you don't have friction plate to friction plate anywhere. Plain to plain is fine.
    Of course, if the noise of the Ducati dry clutch is music to your ears and you have plenty of money, don't bother.
  3. To be fair, I quite like the "characteristic" rattle of the clutch. Just concerned it will let me down in the middle of nowhere. Never had to replace a MC clutch before, so don't know what symptoms to look for. It's not slipping, and its smooth enough on the take up, but the bite is quite up.
    It was Ducati Leeds who said it needs replacing. If I whip the cover off, what do I need to check for myself?
    Thanks
  4. It would be unusual if the friction material is badly worn. These clutches usually get replaced because of wear between tabs and basket.
    It won't let you down because of that though.
    The characteristic rattle is the sound of the tabs bashing the basket. As they wear, the clearance gets bigger and they wear more, so the wear accelerates.
    Putting a friction plate in first stops all that.
  5. So I just whip all the plates out, put an old friction plate at the back, and put them all back in the same order? Will I need the special too for that? Thanks
  6. No
    Nope, no need for any special tools, it really is as easy as that :)
    If you don't have an old friction plate, you can even reorder your existing plates. I know someone who did that and it works perfectly.
  7. The mod relies on the fact that the basket slots are machined in such a way that there is a curved end to the slot. If you put a plain plate on first, the friction plate tabs remain in the parallel sided section of the slot but if you put a friction plate in first, it sits right down into the curve at the bottom and jams in there. It then damps the movement of the whole stack, so no more oscillation, no more chattering, no more accelerated wear :)
  8. I would agree with what has been said already, these clutches are very robust, even though they sound like they are rattling themselves to death. How many miles has your present clutch done?
    If it's not slipping when you open the throttle in a high gear at low speed then things are prob OK. But you can check the conditions of the plates if you are worried. The only special tool I use is a wire coat hanger, cut two straight bits about 100mm long and bend the last 3- 5 mm over at one end - makes it easier to fish out the last few plates at the bottom of the basket. All the plates should have roughly the same amount of meat, a lot less meat than you would expect if you are only used to single plate car clutches. if they are unevenly worn then you need new plates, rotors and springs and maybe a new bearing in the pressure plate. Check the tabs aren't cracked or too burred over and check the slots in the basket - if the slots are badly worn you need a new basket, but otherwise you can just replace the plates.
    I was told by a dealer my ST3 needed a complete new clutch and basket, that was 9000 miles ago, the clutch had been replaced 20,0000 miles ago according to the service history. I fitted suzuki gs650 wet clutch plates ( you can search the forum for a thread on this). I do a bit of commuting and it didn't work because the clutch kept dragging when hot. I refitted the original plates except 2 at the top of the pack which are the gs650 plates. It's working fine and looks like it can easily do another 9000 miles.
    I tried the quiet clutch mod, makes it sound like a tambourine so I changed it back to the proper rattle of the unmodded clutch :)
  9. I too was persuaded to try the Suzuki clutch plates and had exactly the same problem.
    The tabs were just too tight a fit in my clutch basket and got worse and worse as the motor got hotter.
    My solution was to keep two of these plates at the bottom of the stack , so that the old plates could still clear even if the new ones jammed.
    Worked a treat.
    Yes, with the clutch now quiet you can hear the plates jangle when you pull the lever but I don't spend much time with the lever in and I don't dislike the sound anyway.
  10. Thank you everyone for your invaluable input. Most appreciated. I will keep you posted once I get a change to whip the cover off.
    Oh, and for the record, it's only 10k miles ago since the clutch was last done.
  11. Should only be worn tabs and maybe grooves cut into the baskets.
    Quiet clutch should eliminate any backlash resulting from that :)
