Hi all I have a new end can on order and wondering how big a job it is to remove the old one ? Thanks in advance l.
2 minutes Remove pillion footrest hanger - 2 bolts remove small bolt at the bottom of the black metal exhaust cover - nearest the rider foot peg, loosen the large bolt on the exhaust pipe clamp - can be seen from underneath wiggle can and it will then slide off. No need to remove the black metal cover as the whole end can comes off in one piece. With care you can even do it with the pillion hanger in place, just be careful not to scratch the black exhaust cover.
