1098 Steering Damper Fixing !!!
Discussion in '848 / 1098 / 1198' started by Duke Of Wales, Sep 16, 2015.
  1. Hi , wonder if anyone can help me ???
    On a 1098 S Tricolore , the eye (rose joint) at the end of the damper, right hand side , where it bolt's to the frame , is there anything that fit's between the damper / rose joint & the frame ???
    Cheer's ...
  2. You can check the parts list that you can download from Ducati.com. Andy
  3. OK thank's for your reply ...
  4. If ya aint found owt,, its a spacer...............
  5. Part no - 713.1.209.1A Spacer
  6. Thank's for all your help . £2 all in ...
