Stepper Motor Value
Discussion in 'Technical Help' started by ben155, Apr 5, 2018.
  1. I see on guzzidiag 1=idle stepper base , 2=idle stepper break ,3=idle stepper controller.What does this mean?
    I read that stepper motor depends on temperature engine.Only in start-up stage, the engine control unit signals the stepper motor to let in
    supplemental air downstream of the
    throttles.
    When i turn OFF the main key switch,the connection ecu -guzzidiag is still there for 3 seconds ,the idle stepper break increases and stoped at 176.
    What are the usual values for these indications(1-2-3) at idle??
