Dose anybody know of any graphics company that make kits for the multi other than Vulturebike. Com ?. Thanks in advance.
I think there is a guy on Facebook who advertises he can create what you want. I got this from Vulturebike, I had to contact them to get them to do the grey option for the lettering
Sorry to derail the thread, did you powder coat or anodise the belly pan and pillion pegs? I have the same guard from evotech and getting the belly pan done is the next job.
I did myself. I’m not totally happy and I got a few bits of dust under the stickers but it wasn’t too bad. Just thought it broke up the white a bit more. I had to email them, but very helpful. There was a Black Friday deal and of course now you might end up paying extra customs charges
+2 on the Vulturebike stuff. High quality graphics...very thick stock. Designed to be able to be stuck and unstuck several times to reposition or to remove air bubbles. Process is very much like the vinyl wrap where you lay it down best you can and if it has a wrinkle or a bubble, pull that section back up, add some heat via a heat gun, and re-squeegee it down. I'd never done anything like it myself (never done Vinyl either) and it went pretty drama free. They'll also customize any design for you if you ask...I had the front snd rear number plate kits done in matte finish versus the default gloss. As noted above, they respond very well to Email. I had to reposition several times to get everything to line up perfectly with body lines. Just work a clean, warm environment and you get several shots at it.
Only one place to go, The Image Works, Ted and Graham. They do work for main dealers, creating specials using just decals, they have done work for OEM specials and loads of custom jobs.
