Complete original STM Evoluzione 90mm ball and ramp slipper clutch for bikes with 20mm clutch spindle I have personally used with 998s 2002 it but should fit most dry clutch engines with 20mm clutch spindle (748 996 998 999 most monsters 900-1100cc up to superport pre 2008 etc) please enquire if you are unsure I also have a 25mm conversion kit for this clutch available separately which allows this clutch to fit bikes with 25mm clutch spindle (hypermotard, 1098 streetfighter etc) Clutch is 100% working well but cosmetically it has some scratches and marks to the face of the pressure plate from gravel rash. The Drum, and the ramps have wear from track use but still have plenty of life left. this clutch will work with OEM 12 tooth or with 48 tooth STM basket and plates (basket and plates are NOT included ). these are around a grand new , asking £225 uk posted This clutch is not going to win any style prizes but its still a good and cheap way to improve your day if you are planning on taking a big lumpy ducati out onto a race track
