1200 Strange Noise After Throttle Balance
Discussion in 'Multistrada' started by Neo9686, Jul 6, 2020.
  1. Hi everyone, I balanced the throttle bodies a couple of weeks ago troubleshooting another problem and replaced the APS sensor, but since then I have a really annoying noise that occurs every time I ask a medium thrust from the engine.
    The noise is metallic, like two little pieces of aluminum lightly scraping each other, causing a high pitch noise that you could imagine like a cricket's sound, only louder and more metallic. Sadly I don't know how to record it.
    I think it comes from the right, a bit to the front of the bike, but I can't be sure about it. Do you have an idea on what it could be? I'm out of ideas at the moment.
    Thank you!
    EDIT: something I thought about is the throttle bodies link rod. Do you have some play too? I can easily move it on the front cylinder part...
    #1 Neo9686, Jul 6, 2020
