1098 Strange Start Sprag On The Way Out?
Discussion in '848 / 1098 / 1198' started by Old Jock, Jun 27, 2019.
  1. So I've got a Nemesis II in the bike and really like the map, seem to get the OBD light now and again just when starting, it junks the 1098 soft (or servo start) system which suits me fine I hated that.
    Out on a run today, left a cafe and got the OBD light up, first time for a long time, bike started normally. Switched off and restarted and all good, no light
    Went up the road a few miles and pulled in for petrol. About to pull away thumb the starter and the starter engaged but didn't seem to turn, OBD light came on
    Tried a second time, started normally and quickly, crapped myslef at the thought of being 100 miles from away with a bike that wouldn't start, so just came home
    Checked back home fired up like a good un
    What's the opinion peeps, sprag, unlucky?
    Does the problem get gradually worse or does it just fail, I'm thinking if it's gradual I'd just keep an eye out and monitor it. If they usually just fail then I'd go in for a look
    How easy is it to get it off for a look? Are they expensive?
    I need to read up on the Nemisis as I don't know if the fault codes are stored in it and acessed via the Nemisis comms or the dash in which case I guess it would be Ducati Diag I'd use
    Welcome even insults at this point
    Apart from that the bike runs great, but might need a TPS reset, the idle semed to jump up to around 2k, whereas normally it's about 1500
    John
  2. My bike had done just under 30k when it finally went. That is to say it turned over but just wouldn't start. It had been going over a period There wasn't any Mil lights
    I connected up my diagnostics and the codes said that the coils, injectors and CPS no signal.
    I changed the relay first then the coils and CPS. No difference
    I put it down to the sprag. The starting circuit was drawing so much current the ECU wasn't getting enough current/volts
    While I had it open I fitted a new starter as well as the sprag, starts like a good un now
    If you fit a sprag, while its open you should fit new brush kit to your starter. On the 1098 you have to take the starter off to fit the brushes so you might as well do it all at once save opening it up again
    Electrex sell Brush kits about £30
  3. It happens gradually.
    I used to get the EODB light after it failed to start.
    Replacement is fairly involved/easy depending on your spanner skills. Get a crank holding tool as the nut requires round 240Nm torque ( I will check that, hazy memory).
    Cost of parts alone is around 400 quid as to do it properly you need the clutch, flange, starter gear and new nut.
    “They all do that, sir”
    Correction - nut torque is 330Nm!
    #3 RickyX, Jun 27, 2019
  4. Thanks for the replies
    I'll keep an eye on it for now and see if it was just unlucky or it starts to repeat
    Ouch 330 Nm Gawd!!! I'm no ace mechanic @RickyX but can spanner a bit
    Going to take off the fairings tomorrow do a TPS reset, tighten the throttle cables (bit slack) see what the error codes were, then take it from there.
