Success. Its alive.
Discussion in 'Supersport (1974-2007)' started by ducatijones, Aug 10, 2013.
  1. Thanks all for the advice guys. Stripped down the ignition bits, cleaned all connections, tested coils, treated it to a new battery. Back on the road. Did the in gear push in case starter motor stuck. So I don't know what the exact problem was but it seems cured. That's Ducati's I suppose.:upyeah:
  2. You hadn't opened your wallet far enough.........that's what it was.......:wink:
