Normal length brake & clutch levers from Evotech. https://evotech-performance.com/col...lding-clutch-and-brake-lever-set-2017-onwards The clutch lever has been modified with a grubscrew because on the nearest setting to the bar, they did not activate the microswitch in the housing; works perfectly in all settings. Some witness marks from fitting, otherwise excellent. £80.00 posted (UK)
