IVE PUT BST'S AND A TTX SHOCK ON THE REAR OF MY BASE PANNIE ALSO A 42 REAR SPROCKET SO THE RIDE HEIGHT IS OUT OF WAD, I WAS THINKING OF HAVING A FULL PRO SUSPENSION SETUP AND MAYBE CHANGING THE FRONT INTERNALS TO SUIT MY WEIGHT, ANYBODY DONE IT? SORRY FOR THE CAPS JUST NOTICED
I doubt you would need to change the internals. If you are planning a track day try Colin at 100% suspension otherwise post where you live and some one will no doubt recommend somewhere local.
cheers, im in notts, mansfield..i just want to get a good road setup and its probably the best thing you can spend your money on
You're ride height should be fine. They'll do your front and back sag and set your compression/rebound to a good starting point. I use Paul at Ducati Servicing & Suspension Specialist In Southampton but he is near Southampton so a long way from you.
Yep Nelly at Cornerspeed is right on your doorstep, can't remember whether he actually does suspension but he's one of the best Ducati service centres in my opinion so well worth popping by for a chat. He's definitely who I'd use for all service work for Ducatis regardless and so I'm pretty sure he'll know where to point you for suspension. Failing that Ktech aren't a million miles from you, you can get to them just a few junctions down the M42 (conkers turn I think) They helped me with my 848 and as they manufacture suspension I'm fairly sure they'll be able to dial in the panigale
+1 for Colin at 100% Suspension. He's done a couple of my bikes now, and his depth of knowledge and feel for the bike is as good as you'll ever get He sets the suspension up for around 60% of the BSB paddock, but is hugely knowledgable on road applications too. Home
