hi. Weigh in about 85kg with gear. Picking bike up this week. Wondering if anyone can recommend a good starting point for olins suspension changes or are stock settings pretty sweet for my weight? Will be doing mostly road duties with an occasional track day. I've tweaked other bike suspension before so understand the principles... Just wondering how the factory setup is and if any improvements to this as a general rule. Thanks.
I got mine set up by a guy who used to do BSB. I'm about same weight Front: Prealod - FULL in (he reckons need re-springing) Compression: 10 out Rebound: 1 (to cope with pre-load Rear: Pre-load: wound UP about 5mm from delivered settings Compression: 13 out Rebound: 13 out
