749 Swapping A 749 For 999 Engine
Discussion in '749 / 999' started by gazza20, May 15, 2016.
  1. Hi just curious how much work is involved swapping out a 749 motor for a 999!? Appreciate any replys
  2. Straight swap, if 999 engine is a shallow sump.
    An afternoon will see it done
  3. Are all 749's shallow sump then?
  4. It may idle but I would not run it without the correct map installed
  5. I think hardware wise it should be a straight swap but almost certainly won't even idle due to the ignition timing being programmed for 749. Either that or it will run horribly
  6. You would be able to pick up a 999 ECU cheap enough
