749 Switched Live 749/999
Discussion in '749 / 999' started by Shaun, Jun 5, 2020.
  1. Does anyone know if there is an easy to access switched live somewhere near the battery please? Need one to power an accessory and I can’t find anything using search on the forum or the interwebs.
    Cheers
  2. Found one via YouTube. Red wire in the ignition block, that’s what the guy on youtube called it, white 4 wire multi plug on the frame above the battery.
  3. Careful you dont short the ECU , that controls the fans on/off.
  4. I took it for a test ride last week. Did about a 10 mile round trip with no issues.
  5. I had an issue with mine.....didnt effect running etc.
    The ecu shorted somehow & right fan coming on by itself. Dunno how short happened. Ecu controls the fans...
    Fyi in case
  6. Thanks for the info Dubs. Any idea where there is a safer 12v switched live I can use then?
  7. Sorry mate, no idea, i only learned of my issue here. Someone will reply im sure....
