I thought i had my sat nav mount for the 848 all worked out. I was going to drop a telferizer in to the middle if the stem. Then i noticed that the stem nut is not hollow like it is on the Panagale. Arch! Is a hollow one available or is it a big job to do that? Bob at Telferizer said its a big job but i thought i would double check with you. I will probably just go for the clip-on insert version instead. A guy on another forum did drill and tap one of the holes on the stem nut to fit a ram mount but i don't have the engineering skills needed for that. Dub
Has anyone seen the telferizer that mounts on the bolt next to the key in real life? Wondering if it is better than the one that goes in to the clip on.
