Termi Cans Do I Newed Link Pipes
Discussion in 'Ducati General Discussion' started by Gary gibb, Feb 6, 2017.
  1. do you need link pipes for the termi cans or will my standard link pipes do
  2. On the 1198, the oem link pipes are welded to the oem cans, so yes, you will need the Termi link pipes, unless you are fitting them to a full system, where the links pipes are not needed.
    #2 Swiss T, Feb 6, 2017
  3. anyone got link pipes
  4. hes going to send the hole unit that came off his 1098 will this fit my 1198
  5. The parts diagram shows and lists the stock end cans and link pipe as separate items on both the 1098 and 1198, not welded. Andy
  6. can someone help me here need springs and link pipes
  7. Follow the link I sent you and it will give you the correct part numbers. Then talk to the parts department of your local Ducati dealer or look on eBay. Andy
  8. looks like there welded to can to me
