916 Termi Straps.
Discussion in '748 / 916 / 996 / 998' started by yellowducmaniac, Jun 23, 2022.
  1. Hi all,l i just acquired a pair of Termi slip ons for my 916 but they came without the strap hangers ,the stock ones are too loose, anyone know where i can get a pair to fit?...i have fitted them in the interim by packing them out with strips of rubber matting cut to size ,not ideal but better than nothing until i can get the right bits.
  2. Lousy seller. Cant help you mate
  3. I may have hangers without the rubber. Not sure will fit termis but pm me and i can measure the internal diameter and let you know
  4. Just ordered a pair of under seat strap hangers from Pipewerx, 35cm circumference and they fit the Termi cans perfectly, and are a quality alternative to the Termi items.
  5. The 748SPS came with standard exhaust and Termis, which If the same diameter as yours might help as the straps have a part number and may still be available. If you can acurately measure the circumference I could check the ones I have and if the same, the following part number may be helpful ('Strap Carbon silencer' 57610191B). There is no specific part number for the rubber, but I think they use the standard exhaust rubbers (78810481A 'Gasket'). I checked at the beginning of the year and the rubbers were still available but not sure about the Straps. Hope this makes sense.
  6. Thanks, but i've now managed to source a pair.
