For some reason my full Termignoni D200 system for the Panigale V4 came with one spring and sleeve short. The spring is (untensioned) 80mm long (hook to hook) and the Termi embossed rubber sleeve is 40mm long. I have already contacted the UK importer but they are not hopeful. Wondered if anyone had any lying around that match the above criteria. The odd thing is the kit was packed correctly (according to the content list), but Termignoni themselves have the wrong quantities listed yet still pack the contents that way. It SHOULD be 12 long springs and sleeves and 4 short springs and short sleeves. Instead they give you 11 long springs and sleeves and 5 short springs and short sleeves. The extra short spring and sleeve won't obviously fit the one remaining point on the system I need to fasten. Point being that if this is the case, every purchaser of this system is going to face the same predicament!!
Got these Rod, I think the one with the rubber on is maybe the one you need ? it has a nick in the rubber but if it’s at the back you wouldn’t see it
Thanks for taking the trouble to find them Ian. I managed to get one from the UK's Termignoni importer, so all sorted now. I will bear these in mind though, if ever I need a spare.
